Supra rear diff on Escos??
Old Mar 13, 2015 | 08:09 AM
delbee1's Avatar
delbee1
Default Supra rear diff on Escos??
Can a 3.7 supra rear diff be used on an Escos still running 4 wheel drive??
Old Mar 13, 2015 | 08:40 AM
Caddyshack's Avatar
Caddyshack
I think you MAY need to change the drop gears in the gearbox but maybe it is close enough to the front ratio?, Give Bara motorsports a call and speak to Bara, he can rebuild the supra diffs with the maxi kit and also advise on the ratio and supply whatever you need, he is a top man and his service is the best.
Old Mar 13, 2015 | 08:58 PM
jsa's Avatar
jsa
3.7 & 3.6 are too far apart.
Toyota do have a 47/13 C&P that is the same tooth count as EsCos.
Edit; fixed, now 47/13
Old Mar 16, 2015 | 12:28 PM
ossie cossie's Avatar
ossie cossie
43 and 13 is a 3.31 ratio i think that is wrong. escos is 3.62
Old Mar 16, 2015 | 12:29 PM
ossie cossie
43.11 is 3.9 ratio
Old Mar 16, 2015 | 12:31 PM
ossie cossie
40 to 11 is 3.63 ratio how many teeth does a coswort diff have crown and pinion? thanks
Old Mar 16, 2015 | 12:32 PM
ossie cossie
can you get a 3.9 ratio for the front diff of an escos?
Old Mar 16, 2015 | 02:30 PM
delbee1's Avatar
delbee1
Thought getting a Supra diff would be cheaper and more reliable than getting an uprated Escos rear one....
Old Mar 16, 2015 | 02:32 PM
delbee1's Avatar
delbee1
Yeah you can get a 3.9 front, I was also thinking about getting 3.9 front and rear but not sure how that would make a motorway journey???
Old Mar 16, 2015 | 05:51 PM
Caddyshack's Avatar
Caddyshack
It won't make it that short, I bet it would still be geared for 160/170 or more.
I have just got Bara to make me up a new diff, cwp, strength plate and quaife atb in 3.9. Was Ł1400
Old Mar 16, 2015 | 08:35 PM
jsa's Avatar
jsa
Ossie,
Thanks, it's 47/13
Old Mar 17, 2015 | 09:11 AM
delbee1's Avatar
delbee1
What would the 3.9's do for your acceleration?
Old Mar 17, 2015 | 01:05 PM
ossie cossie
JSA. i have a track escort cosworth i am building up and have a supra LSD rear diff to go in it. i have also got a standard supra diff or JZ90 or something with a supposed 3.9 to 1 ratio. it seem you are quite knowledgable in these diffs would the 3.9 ratio crown and pinion fit iob the LSd diff this has a 4.56 i think in it.
Old Mar 17, 2015 | 01:06 PM
ossie cossie
PM me if you want not to hijack the thread.
Old Mar 17, 2015 | 04:41 PM
Caddyshack's Avatar
Caddyshack
It is supposed to make it accelerate faster.
We do need to consider that Cossies have wide spaces between ratios so the turbo can drop off boost, the perfect solution would be a close ratio box. By lowering the final drive you are making all the gears lower BUT the ratios are still wide apart.
I will let you know when mine is finally back on the road...albeit with the skyline box.
Old Mar 17, 2015 | 09:14 PM
jsa's Avatar
jsa
Pm'd ossie
Old Mar 18, 2015 | 02:26 PM
ossie cossie
My track car too will be skyline 4x4 box and 3.9:1 supra rear diff with 3.9:1 escos front diff ratios. Most parts easier to get here in OZ.
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Mickeystewart
Sep 9, 2015 04:04 PM
