RS Turbo Parts - HUGE List - SFS/Pro Alloy/Cossie Brakes etc.
1600 CVH Engine: Around 15k miles on it since the rebuild: £400
Engine & Box coming out the shell this weekend. Pics to follow.
New Standard Mahle Pistons
New End Bearings .5mm
Reground Crank
Standard Shot Peened Rods
Ported Head
Bigger Valves
3 Angle Valve Seats
Kent CVH36 Cam
AP Paddle Clutch
S2 RST Rebuilt LSD Gearbox PROV. Sold Under 4k miles on it
GENUINE Ford Mk4 Wings RARE - Mint Unused - Waited months for delivery import. Pic to follow still in storage.
Still have Ford stickers attached. Impossible to find now. SOLD
SFS Boost Hoses w/ DV take-off £85
New Racetech Fuel Gauge with Sender incl. £60
BBR Boost Gauge £30
TIM 8k Rev Counter £30
New Fuel Tank powder coated silver - Aftermarket £80
Front Doorcards 90 spec - 2 sets - One set with JBL speakers fitted £50 a set
Pro Alloy Half-Mount Intercooler £90
Loom £85
Cossie 273mm Rear Brake Conversion: Everything needed to fit & all powder coated - Bolts/Brackets/Handbrake cable/Braided lines/Calipers/Discs/Pads (All bought from Burtons) (Calipers bought from Paul @ North Yorks) SOLD
NEW Bosch 910 RS Turbo Fuel Pump £70
Genuine Front Lights £35
Genuine Hella Comet Spotlights £40
ALL Polybushes (Some not pictured will update) SOLD
Rear Wishbones w/ Polybushes fitted - Powder coated £75
Stainless replacement nuts/bolts/washers Rear Hubs/Wishbones SOLD
Refurbed Alternator £50
Mint White Wing Mirrors £30 the set
Mk4 Dashboards x2: One has been drilled for LEDS etc. & One standard. (Will get better pics)
-Drilled £25
-Standard £40
Refurbed Rear Brake Lines/Pipes £30?
Fuel filler neck & fuel cap w/ key £25
Reground Crank
Ported Head
Bigger Valves
3 Angle Valve Seats
Kent CVH36 Cam
AP Paddle Clutch
BBR Boost Gauge £30
Loom £85
-Drilled £25
-Standard £40
I'm thinking late sender. Sender can come with but it's pretty knackered, will put up a pic of it now, and some more from top.
Its after market but been powder coated.
£90 or around that. Could do £95 posted
No mate sorry, just these. Make an offer though need them gone.
It's the 044 pump mate...
Can't see why not. I'll check courier prices unless you know a good company for it?
Pm'd
Yeah mate it's still here. I'm North London, Finchley
Someone else already has dibs if I split the clutch. But will let you know.
