Escort Cosworth Idle Problems
Old Feb 24, 2015 | 07:41 PM
shoppel's Avatar
shoppel
Default Escort Cosworth Idle Problems
Green Bosch 803
Marelli 3 bar Map
MSD Chip
Mongoose Decat
-34 Rated T3 Fitment Wastegate Actuator
What could cause this drop down in A/R ratio when idle drops down? I did nothing with the gas paddle!!
Old Feb 24, 2015 | 08:57 PM
RSLUBBY's Avatar
RSLUBBY
Mine did the same thing and it had a leak on the plenum gasket
Old Feb 25, 2015 | 06:07 AM
shoppel's Avatar
shoppel
the gasket is new
Old Mar 6, 2015 | 01:04 AM
Terry Pluck's Avatar
Terry Pluck
Could be the Lambda Sensor.
I had similar problems and it turned out to be this.
Old Mar 6, 2015 | 01:38 PM
James @ M Developments.'s Avatar
Make sure the P8 has had a reset done,
Check and adjust the base idle with the ISCV disconnected,
check the ECU voltage is stable, and check the lambda function as mentioned as a starting point.
Vincereese
Jun 1, 2023 09:14 AM
jessie_rs
11
Jun 3, 2019 04:57 PM
James Porter
Aug 26, 2015 10:51 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
