2008 1.8 Diesel Focus Estate - Coolant leak found - what's this called?
Hi,
I've found a coolant leak but unsure what the part is called in order to replace. It's the plastic joint - the right one (not left) that connects pipe to middle (round) box. The side you can't see gushes coolant when engine is running. Its in the middle of the joint and not the edges that pipe connects to so I'm sure I need to replace it. I can even put my finger on it to stop the leak.
Looks like egr cooler to heater matrix hose (top hose)
Mark - see picture 5 where hose goes to bulkhead - any idea how to release the hose? I have a replacement and can't get the old one out.
I think the idea is to twist the grey end and pull but I can't get it to, do you do if there is a release catch?
Thanks Chris
Do the hoses go through the bulkhead to the heater matrix?
RichieST - see picture 5 where hose goes to bulkhead - any idea how to release the hose? I have a replacement and can't get the old one out.
Thanks Chris
