mondeo mk3 no injection signal
Hello Guys!
Im new here, you are my last chance!
I have a 2004 mondeo HJBB 115hp. My problem is the 3rd and 4th injectors dont work, I have checked the connectors, they are dead.
I have checked with mulimeter, no signal .1st and 2nd have signal.
I have checked all the wires to the ecu all good,
No fault code in the ecu at all.
I dont understand because 1&4, 2&3 are on one +line in the ecu
before we renewed diesel pump, injectors were checked cleand, measured compression: 30, 28, 27, 28. changed CMP sensor and Crankshaft sensor.
So everything should be ok, BUT
Sorry for my English but Im Hungarian:
Kind regards: Peter
Kind regards: Peter
Could be a dead ECU. Don't forget you have cylinder order as 1 - 2 - 3 - 4 but the injectors are probably numbered by firing order, be it 1 - 3 - 4 - 2 or whatever it may be.
Hello Guys!
Huston we got a problem!!
It looks like there is a TDDI Flywheel instald!!!!!!!!!!!!
WE bought the car from Germany, so congrats to the mechanic who Put it in!
But still not sure of that this causing then problem.
Any idea??
Kind Regards Peter
Any idea??
Kind Regards Peter
mk3ste
Oct 17, 2021 10:09 AM
wowk
Mar 30, 2021 07:49 PM
Steve Escos
Oct 1, 2015 06:57 AM
