Move Strut Tops or get Adjustable TCA's?
So i'm converting my mk2 cortina to a savage (v6) and have decided to put the capri chassis legs on and run the whole front capri axle (and back but that doesnt matter) including the crossmember etc. Now, the strut tops of a capri are 25mm wider than my cortina ones (all together so 12.5mm each side) and thinking or have been told that this may be a problem when it comes to camber/caster. Was thinking this could be sorted with adjustable tca's or should I just move the strut tops while i'm there?
Ryan
Ryan
Cheers!
I have looked into it, but I have heard bad reviews about adjustable top mounts on road cars. (Mine is my going to be a track car, or at least not for a couple years)
But if worse comes to worst then I would buy the adjustable top mounts and test them out before I move the mounts. Thanks!
FlashRS
13
Aug 31, 2015 06:02 PM
track.focus'd
Aug 12, 2015 05:53 PM
