breather system
Old Apr 1, 2005 | 06:24 PM
fowls@blueyonder.co.uk's Avatar
fowls32
Default breather system
i've brought an uprated breather system to replace the crap ford breather thats already on it,basically it looks very simular to the baileys one it has four outlets on it,i basically need to know where the four outlets go that are on the breather(its a stainless steal one)when i use to it to replace the old one-basically i need a idiots guild on how to do this job
any help or info will be grate ful
Old Apr 1, 2005 | 06:37 PM
Davey8oy's Avatar
Davey8oy
fowls@blueyonder.co.uk,
Alright dude one goes to the left hand side breather outlet on the rocker cover, and also to the right! and there should be a tube comin out of the bottom of the breather??? this goes to the breather at the back of the engine on the right hand side (if your standin in front of the car) just above the sump!! and the forth can either go to to the meterin unit, the same place the standard one goes or you can put a filter on it! make sure you block the pipe off on the meterin unit cos the car wont run due to bein close vented!!
Old Apr 2, 2005 | 10:41 AM
Rick's Avatar
Rick
as above - but defo dont run it to the metering unit - block that off..
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
