For Sale New & used Escos parts **CLEAROUT**
Due to my soon departure to the land down under i have decided to have a good clear out of parts ...i still have some parts left but i will list them as and when i find them.
Im Having trouble uploading pictures so if anyone wants any pictures please ask and i will try and upload them
*parts off Big turbo Escort Cosworth*
**POSTAGE NOT INCLUDED** can post at extra cost but bigger items will need to be collected or you can arrange a courier to collect
*x4 Brand New 83lb Siemens VDO injectors "still in packet" SOLD
*Brand New twin ignition module brackets in polished stainless with "RS" logo £35
*Original Escos Rad off low mileage car "NO LEAKS" SOLD
*Original Rad Fans off low mileage Saff SOLD
*Original Escos Intercooler in good condition SOLD
*Polished alloy Strut brace SOLD
*Original BT Header tank £40
*Original PAS tank with mounting bracket £30
*Original "UNCUT" BT Engine loom SOLD
*Polished alloy Front strut tops SOLD
* Instrument cluster surround £30
*Centre section of dash complete with vents SOLD
*Dash vent £10
*Koni adjustable front & rear shocks with 25mm drop Eibach springs SOLD
*Front calipers c/w brake hoses, "NOT SEIZED , No leaks" comes with pads £100
*Standard Gear linkage cradle SOLD
*Pair Standard TCA's with polybush bushes £45
*Original Fuel lines from under bonnet to Tank £50
*Original Rear caliper brake pipes "Good condition" £15
*290 mm Black Diamond grooved front discs SOLD
*4 alloy gear box cradle/linkage bushes made from aircraft grade alloy £25
*Long Blue Wasted HT leads "covered 20 miles !!!" SOLD
*Near New B&M short shift linkage £275
*Original front Anti roll bar £40
*x4 Braided fuel lines with goodridge ends , will do all the lines from fuel rail to tank & filter £150
*Original Dash panel for passenger side "above Glove box"...needs a clean £40
*Brand new polybushes for front anti roll bar £30
*Original Engine mounts SOLD
*Brand New Powerflex Exhaust mount £6
*Original Rear diff mount £30
*Polished SPEC R Alloy Cam belt cover with Cosworth etched in £160
*x2 10" 1100 Watt each Infinity subs in box £100
*17" American legacy 800 Watt Sub in box £40
*Original Escort Cosworth Dash removed from a low mileage car (please note some bell end has cut a rectangle out of the bottom of the glove box to install a cd changer ) if you are any good with a plactic welder then this can be easily repaired. Could do with a good clean as its covered in dust
£ 50
Thats all the parts for now , i have a mt75 gearbox and internal rear diff i need to get pictures of aswell as some other parts but will post them soon
pm me for any parts
paypal :- andrew.ramsden@yahoo.com **gift only**
*Dash vent £10
£ 50
pm me for any parts
