ecu repairs
Old Feb 8, 2015 | 08:15 AM
whizzisat114's Avatar
whizzisat114
Default ecu repairs
Hi all does anyone know of any company that can check and repair a l8?
It was plugged in to a loom with wasted spark fitted but not fitted to ecu (pins not cut)
Cheers in advance
Old Feb 8, 2015 | 08:50 AM
stevieturbo's Avatar
stevieturbo
C**t
And why do you think it is damaged ?
Old Feb 8, 2015 | 10:37 AM
whizzisat114
Won't prime pump now
Old Feb 8, 2015 | 10:55 AM
Paul_RS's Avatar
Paul_RS
Have you checked the ECU fuses aren't blown? They are under the glovebox.
Old Feb 8, 2015 | 11:26 AM
stevieturbo
C**t
And is that the only symptom ?
ie are you getting any spark ? Are you sure the fuel pump is capable of working ?
What exactly happened between it working before...and not now ?
Old Feb 8, 2015 | 02:09 PM
COLEYST200's Avatar
COLEYST200
I no 100% that this ECU is faulty as a long time back it was put on a standerd car and it did not do a lot . But I can not remember exactly wot it did not do .
I all so would like the no if there is any good ECU repair places that could look at cosworth ECU,s as I all so have a L8 that's faulty
Old Feb 8, 2015 | 03:42 PM
Karlos G's Avatar
Karlos G
Balls Deep!
MSD can repair them mate.
Old Feb 8, 2015 | 04:39 PM
timster's Avatar
timster
This is the guy who repaired mine
http://www.the-ecu-doctor.co.uk/
had a really weird fault where it would stop firing one injector intermittently. My ecu was also fitted with wasted spark so shouldn't be a problem for him. Mine is a L8
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
gambo08
Feb 4, 2016 10:49 PM
griffo69
Oct 4, 2015 11:58 AM
rsguy
44
Sep 29, 2015 03:29 PM
