Some advice needed please on Sierra cosworth fuel gauge
Hi guys I've bought a Sierra RS cosworth and the fuel gauge hasn't worked since I've got it and want to fix it as its annoying
It's stay up up to 3/4's of a tank and when the ignition is turned on it goes to the top,I ve disconnected the 5-6 pin connection in the boot (back panel) as am I right in thinking this would rule out the float as its not getting a reading so wouldn't rise? Has anyone else had this issue and if so could you please help me out.
Also my Rev counter isn't worked as I am running a coil pack and believe there has to be something done to the dash instrument
my pals a sparky but a nightmare to get a hold off but if I drop the clocks into him then shouldn't take much to do
I'd be very greatful for anyone's help...
Thanks for taking the time to read this
Scott.
It's stay up up to 3/4's of a tank and when the ignition is turned on it goes to the top,I ve disconnected the 5-6 pin connection in the boot (back panel) as am I right in thinking this would rule out the float as its not getting a reading so wouldn't rise? Has anyone else had this issue and if so could you please help me out.Also my Rev counter isn't worked as I am running a coil pack and believe there has to be something done to the dash instrument
my pals a sparky but a nightmare to get a hold off but if I drop the clocks into him then shouldn't take much to doI'd be very greatful for anyone's help...
Scott.
Aug 14, 2015 07:29 AM
