General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Hi all. Im building a zt to put into my mk3 rs 1600i the car should be around 400bhp and was wondering if my brakes will be up to the job of stopping it?
The brakes set up I have now is..
Front = cosworth 4x4 calipers and 2wd discs
Rear = cosworth 4x4 calipers and vented discs
And a mondeo servo & ms
I want the car to look completely standard on the outside so that was the best I could afford that'd fit under standard wheels but will they be ok? The car is only going to be for road use.
Reason: .
You can get AP's that fit under 15's mate from Reyland, I;d be running those with 400 horses
Iv seen them but there a bit out of my price range at the minute, im still getting over the cost of Christmas and the tax man has just bent me over! Plus bills bills and more fucking bills! Lol. But once im sorted I think il be looking more into them they look the best bet for fitment under the standard wheels
i ran frs gear under some 16's, took a lot of fiddling to get them under though.
so mondeo 300mm stuff should fit, i'd even try to get pug 406 brembo 4 pot calipers and mondeo 300mm discs as an option if you fancy a little work and not a lot of expense.
I thought the brembo calipers had no chance of fitting under 15" wheels?
They won't with frs discs, but I'd be confident with a smaller disc.
406 ones use a smaller discs and pad.
Just thinking spread aloud, i got told i wouldn't get brembos and 324mm discs under 16's but i did.
