Ford Focus 06 Plate - Fitting Aux Problems
Old Jan 31, 2015 | 09:34 AM
FordJonah's Avatar
FordJonah
Default Ford Focus 06 Plate - Fitting Aux Problems
Good Day All,
Had a search of the forum and could not see it
I have the above Focus and have decided to fit a aux input. Now I have enlisted the help of a mechanic who has fitted a few and we cannot get the radio out, we have tried Ford keys, the ones the garages have that fit all cars and even steak knifes. It seems like one of the catches is cabbaged, nothing catches on it.
Now what do I do in order to get this radio out? Anyone recommend anyone in the Merseyside area or is there an alternative way
Thanks
Old Jan 31, 2015 | 11:00 AM
The way ive got them out in the past is by putting the 4 radio pins in then put 2 long screw drivers through the pins and pull like fook lol.
Old Jan 31, 2015 | 11:14 AM
chris cdti's Avatar
chris cdti
They are a bit of a twunt to get them out. The pins just about push the locking springs out of the way. Its like the slot for the pins isn't wide enough to let you get more leverage on them and even then they bend and get stuck on the way out.
Old Jan 31, 2015 | 08:08 PM
220tel's Avatar
220tel
you checked you have not got the input already in the glove box
Old Jan 31, 2015 | 10:09 PM
FordJonah's Avatar
FordJonah
Tried everything to get it out and there has been no joy.
I had the glovebox out changing a pollen filter and nothing stood out. What is it I am looking for?
Old Jan 31, 2015 | 10:26 PM
chris cdti's Avatar
chris cdti
A circle on the top of the inner part of the glove box. The jack has two wires going to it that you will have to disconnect ti remove the inner part of the glove box.
Old Jul 12, 2015 | 12:07 AM
FordJonah's Avatar
FordJonah
Took three mechanics about 20 minutes to get there out. Radio went back in nicely but the one corner doesn't look right and there is slight markings on the silver surround. One horrid job and I think I have only used the aux about 10 times since I got it done
Old Aug 27, 2015 | 05:43 PM
FordJonah's Avatar
FordJonah
Had a nightmare here lads
Some nugget has changed the battery but hasn't managed to keep the power to the radio and so it needs the code.
Now is there a way to get the code without removing the radio? That radio is a bastard to get out
Old Aug 27, 2015 | 06:07 PM
Nope not unless you have the code with the service history. But since your posting on here i doubt you have.
Old Aug 27, 2015 | 06:19 PM
FordJonah's Avatar
FordJonah
Going to have to pay the garage to get it out again
The funny thing is that the code is written next to the serial code
Oh how we laughed
Old Aug 28, 2015 | 09:27 AM
FordJonah's Avatar
FordJonah
Is it printed in the audio book?
Old Aug 28, 2015 | 07:07 PM
It should be written in a section which as code on it and 4 squares
Sometimes there is 2 stickers with it on too.
Old Oct 6, 2015 | 08:03 PM
FordJonah's Avatar
FordJonah
Got this in the end, Ford had to rag the radio out and it took the master tech 1hr
Cost me Ł15
Old Oct 7, 2015 | 12:24 PM
salsheikh's Avatar
salsheikh
sorry i didnt see this thread earlier but you can ge the serial number by pressing 1&6 or 2&6 together and then scroll down - i find this info on ebay!
Old Oct 7, 2015 | 06:37 PM
DangerousBryan's Avatar
DangerousBryan
1&6 works on most of the Ford radios and some of the Sony ones.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
track.focus'd
Aug 12, 2015 05:53 PM
taylora1409
Aug 12, 2015 12:06 PM
