4x4 cosworth rebuild front and rear diffs 3.9 £400 the pair
Old Jan 28, 2015 | 10:26 AM
RIB1122's Avatar
RIB1122
Default 4x4 cosworth rebuild front and rear diffs 3.9 £400 the pair
Im selling my pair of freshly rebuilt diffs.
3.9 ratios,
Just had a full overhaul, vapour blasted casings, new bearings, seals, spacers, shims, new crown wheel and pinion, strengthening plate in the front diff etc etc
Not done a mile, sat on the shelf £400 delivered the pair
Old Feb 14, 2015 | 04:30 PM
Caddyshack's Avatar
Caddyshack
If you get a buyer on the rear I may be interested in the front one
Old Feb 14, 2015 | 10:15 PM
c20tbo's Avatar
c20tbo
Can the ratio be changed on the front diff, i thought you had to step the gearbox to suit? normal front diffs are 3.6
Old Feb 14, 2015 | 10:37 PM
Jay,'s Avatar
Jay,
Sponsor
Only if you dont change the front diff you use a drop gear in the box which is the better option as the crown wheel in the front diff is the weak link
Old Feb 15, 2015 | 04:59 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
3.9 diffs were used as standard in the DOHC 4x4 cars, physically a straight swap into a Sapph Cos 4x4.
Old Feb 15, 2015 | 10:51 PM
c20tbo's Avatar
c20tbo
Does that make the 3.9 fron diff weaker than the 3.6 cosworth item?
Old Feb 15, 2015 | 10:58 PM
Jay,'s Avatar
Jay,
Sponsor
Yes thats right
dal3door
Aug 13, 2015 06:55 AM
track.focus'd
Aug 12, 2015 05:53 PM
xr4x4rs
Aug 6, 2015 09:03 PM
Old ford
Jul 31, 2015 06:50 AM
