Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
MK5 Fiesta rev counter only dead
Old Jan 22, 2015 | 11:04 AM
amichael's Avatar
amichael
Default MK5 Fiesta rev counter only dead
Suddenly out of the blue the rev counter (only) does not work, the speedo is fine. The embedded lights within the rev dial do work.
I think it started when on the one occasion i tried to start the engine and it just made a click-click, etc sound. classic sign of the starter/solonioid problem. But on my second attempt managed to start the car. Never done it since.
The other thing i noticed at the same time was the radio thought it lost power so I had to put the code in and the electronic trip meter went to zero. Does the rev counter work on a fuse or relay and is it separate to everything else? Where is it?
My car is W reg , 2000, fiesta 1.25 Zetec Mk5.
I read somewhere that if you hold down the trip reset button while you start up the engine, it enters a diagnostic mode and tests all the dash dials and lights - but that does not work on my car, maybe for older fords.
Help.
Old Jan 22, 2015 | 02:36 PM
amichael's Avatar
amichael
Latest news: I tried the trick on holding the trip reset button on startup. This time I pressed it harder and started the engine and it worked.
Rev counter now works!
Is there a web site or pdf online that explains all the test display option counters as you skip through them?
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
Marv888
Sep 26, 2015 03:44 PM
