Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
TDCI possible belt noise
Old Jan 21, 2015 | 06:33 PM
danme1987's Avatar
danme1987
Default TDCI possible belt noise
the engine is the 1.8 tdci mk1 focus. My problem started with a squeel in cold weather which lasted about 10 mins until the engine warmed up.
Anyway, the noise then stopped but has changed to more of a ticking noise (like a blip of a squeel if this makes sense. The noise changes with the revs of the engine.
I am in the process of getting the cambelt and serp belt done but dont want to get it dont and this still make noise.
My concern is that the noise does seem to stop for the most part when the heated screens are put on.
Any ideas guys?
Old Jan 21, 2015 | 07:12 PM
RichieST's Avatar
RichieST
It's probably a worn aux belt. Your mechanic should check the condition of all the pulleys while he's got it in bits. What you can do for a test is get some water in a spray bottle, run the engine and spray some water on the inside of the belt. If the squeaking temporarily stops or changes in sound then you know it's definitely the belt.
Old Jan 21, 2015 | 08:54 PM
danme1987's Avatar
danme1987
Well its going to be changed either way but why would it stop when heated screen is put on? thats what stumped me. I dont wanna get it fit and then have to do it again to replace something else
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
gingeRS
17
Oct 2, 2015 09:42 AM
The Enigma
Sep 29, 2015 10:31 AM
Sp3no
Sep 27, 2015 07:23 PM
