high km Mondeo's
Old Jan 19, 2015 | 02:06 AM
kiwikermit's Avatar
kiwikermit
Default high km Mondeo's
How reliable are high km Mondeo's? Just starting to fish for a daily runabout to replace my old 250,000 km Hilux ( I see rust repairs in my near future). I see 2002 -2004ish Mondeo's about reasonably cheap but usually high km's. What do I look out for and what is likely to give me trouble?
Old Jan 20, 2015 | 08:28 PM
LHD220Turbo's Avatar
LHD220Turbo
petrol or diesel?
Old Jan 20, 2015 | 08:48 PM
Fullflush's Avatar
Fullflush
Flywheels, turbos, injectors
Old Jan 20, 2015 | 09:05 PM
kiwikermit's Avatar
kiwikermit
Not too fussed. Probably a petrol. My hilux is diesel though and cheap as to run. Which is more reliable?
Old Jan 21, 2015 | 06:43 AM
The Crocodile Hunter's Avatar
The tdci mk3s give loads of trouble.
Just look at all the threads on this site about the subject
Old Jan 21, 2015 | 07:15 AM
bj928's Avatar
bj928
get an early mk3 TDDi, none of the TDCi issues
Old Jan 21, 2015 | 09:42 AM
LHD220Turbo
as above the older TDDI engines suffer from lesser issues than the TDCI
Old Jan 21, 2015 | 10:17 AM
Bailes1992's Avatar
Bailes1992
If you're going petrol then I wouldn't worry. They seem pretty bulletproof although the 4 cylinder models do seem to use oil.
Old Jan 21, 2015 | 11:12 AM
There are always a few petrols listed on ebay as spares or repairs needing engines? More than likely that people have run them out of oil?
Old Jan 21, 2015 | 11:15 AM
Bailes1992's Avatar
Bailes1992
Not sure. Could very well be!
I know my Father had a 51 plate 1.8 LX brand new back in 2001 and he always used to go on about the oil consumption. From new it would use a litre over 2000miles. It never got any better or worse though.
There's a fair few threads on talk ford with people mentioning their duratecs use oil.
Old Jan 21, 2015 | 12:33 PM
RichieST's Avatar
RichieST
I don't think the duratecs are as good as they are made out to be. They all use oil and aren't uncommon for ring / bottom end failure. I had a 2001 tddi and it was brilliant, mate of mine has got it now. It's done 100k in our ownership and has done over 200k now. Only problem has been a broken wire in the fuel pump wiring plug but that was easily sorted by an auto electrician.
Old Jan 21, 2015 | 03:02 PM
Fullflush's Avatar
Fullflush
If you are buying a high milage car you want an Audi or VW, not a Mondeo. Unless you want practuce at fixing things every weekend.
Old Jan 21, 2015 | 05:20 PM
turbolee's Avatar
turbolee
plenty of cheap early passats for sale great cars the tdi go for that instead
Old Jan 21, 2015 | 06:46 PM
kiwikermit's Avatar
kiwikermit
I did have my eye on a couple of Passats also. I love driving my wife's Mk 5 Golf GTI. I will keep my eye out for tddi as well though. I will be sad tor see my hilux go but rust doesn't go away like a fwe mechanical isues do.
Old Jan 21, 2015 | 07:13 PM
kiwikermit's Avatar
kiwikermit
I just found a 2.8 Passat 2004 wagon for sale wit 130k on the clock. Would that be a reliable wagon ?
Old Jan 21, 2015 | 09:03 PM
Fullflush's Avatar
Fullflush
You want the 1.9 tdi
Old Jan 21, 2015 | 09:08 PM
In fairness the tddi models will go on and on like a vag 1.9 pd?
The duratec as someone else said i dont think are that good and tdci's forget it.
Mk1 and 2 mondeos with the zetec engines were alot better at covering high milage imo
Old Jan 21, 2015 | 11:26 PM
kiwikermit's Avatar
kiwikermit
Used diesels just don't seem to be on the maret down here in NZ.
wowk
Mar 30, 2021 07:49 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
The Enigma
Sep 29, 2015 10:31 AM
