Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
Beeping indicators?
Old Dec 12, 2014 | 08:46 PM
vtgrrrs's Avatar
vtgrrrs
Default Beeping indicators?
My st170 has started to beep (sounds like it's coming from rear) when indicating left or right. It seems to stop or at least fade when I press the brake pedal. I've checked the lights and they are working. There are no warning lights either and it doesn't have a tow bar fitted. Any ideas on what it is and how to stop it?
Old Dec 12, 2014 | 10:01 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
It sounds like it has the wiring for a previous tow bar fitted and has a poor earth. The electrics think the trailer is attached and make the towing relay beep. Have a look behind the bumper and in the boot area for unexpected wiring.
Old Dec 14, 2014 | 12:41 PM
vtgrrrs's Avatar
vtgrrrs
There does seem to be a lot of wires there now I've looked and it would explain the knackered rear springs.
Question now is how to stop it?
Old Dec 14, 2014 | 01:46 PM
costina's Avatar
costina
Live long and prosper!!
Remove the buzzer
Old Dec 14, 2014 | 02:53 PM
vtgrrrs's Avatar
vtgrrrs
Cheers. Well that was easy! I was worried it might stop the indicators working if I fa f fed about so I just dismantled the beeper (once I found it in the mess of wires) so it doesn't work anymore. Now there's no beeping and indicators still work.
steve.rst
Mar 15, 2016 08:01 AM
Rammer46
Sep 18, 2015 08:31 AM
Cossikev
Sep 13, 2015 02:00 PM
The Enigma
Sep 12, 2015 10:12 PM
