ARE ALL ESCORT COSWORTH CAR LOOMS THE SAME?
Old Mar 31, 2005 | 05:48 PM
craig2016's Avatar
craig2016
Default ARE ALL ESCORT COSWORTH CAR LOOMS THE SAME?
Or did they change them when they brought out the small turbo version??
any help appreciated!
Craig.
Old Mar 31, 2005 | 07:54 PM
THE RADMAN's Avatar
THE RADMAN
do you mean the engine loom or the whole thing? the engine loom will be different id have thought because the small turbo uses a maf sensor ,the temp sensor is in a diff place and the coil packs,ign amp, etc,its also routed differently round the plenum
Old Mar 31, 2005 | 08:21 PM
craig2016's Avatar
craig2016
no just the car loom, yes absolutely sure the engine loom is different, i am wondering if you can plug a small turbo engine loom into an older car loom!!
Craig
big_Rad
Sep 15, 2017 09:36 AM
Escortdriver1
Jul 31, 2015 02:36 PM
Old ford
Jul 31, 2015 06:50 AM
