Turbo Technics 2.8 V6 parts wanted
Hello all,
Would anyone have, or could possibly make, a crossover pipe that runs from turbo manifold on nearside manifold to the off side manifold on a v6 2.8 engine. mine is damaged and i need a new one ready for rebuild.
Also could do with a new, or good condition intercooler if any available. has anyone modified one that will fit correctly.
Thanks.
Thanks.
when i had t/t cars the intercooler always resembled the rs500 type-tbh any cossie one would suffice-but the bigger the better
the pipework will be hard to source unless somebody breaking exact car-then usually sold as a kit-sometimes with engine so you will probably have to adapt/fabricate this-shouldnt be too expensive if you ask about locally-even if you bend and cut your own pipes to shape and get somebody to weld a shoulder around it this does nicely
thanks tony66, i will measure up my old intercooler and try and get one the same as i can then use the original intercooler pipework which is new. it is the end pieces i realy need for crossover pipe as i was given the new stainless pipe without the ends on. i will try a exhaust manufacturer to see if they can get it sorted for me. was only quoted Ł340 for complete exhaust for my celica supra but never thought about asking them about the pipe. think it is old age lol.
The end flanges are standard one side and very similar if not the same the turbo side so it's just a case of bending the pipe correctly then. I made one up on my old turbo xr4 as it had rotted but a decent exhaust specialist should make one for u cheap enough out of stainless. I recently sold a decent tt intercooler, typical still have pipes I think.
muz
Aug 16, 2015 12:57 PM
155lee
Aug 14, 2015 11:21 AM
