Geometry and coilovers
Old Nov 24, 2014 | 08:15 PM
Prickly_buzz's Avatar
Prickly_buzz
Default Geometry and coilovers
Hello,
Right I'm looking to buy a set of AP coilovers as I'm looking to lower and stiffen up the car.
I'm concerned about the geometry being out and killing tyres (as I don't run budget tyres can become expensive).
Is it jut a case of fitting the coilovers and then getting a four wheel alignment done where they can check camber/caster ect?
Old Nov 26, 2014 | 06:12 PM
tony66's Avatar
tony66
Default set up
if you get the height appx where it was and the camber the same it wont be far away..you can set it up yourself with wood/string and a camber gauge if you have the patience..
mk1turboestate
Dec 2, 2015 08:31 PM
S3an
Sep 26, 2015 11:39 PM
CrOwSoN15
Sep 24, 2015 01:36 PM
landaqmabba
Sep 15, 2015 07:16 PM
S3an
13
Sep 13, 2015 10:01 AM
