Fiesta 2004 - durashift & TCM problems
Old Nov 19, 2014 | 10:55 PM
satrader's Avatar
satrader
Question Fiesta 2004 - durashift & TCM problems
hello to all members.
I have a Ford Fiesta 2004 with the ASM (auto-shift manual) transmission - Durashift - which now doesn't want to start.
The warning light of Durashift was blinking and sometimes the car
started after I play with the wires. I inspected the wire loom
(2S6T-14K039-AD) from the clutch actuator (TCM : 2S6R-7M168-GC) to the
selector & shift motors (2S6R-7K004-AC) and all was OK.
After some days, the warning light of Durashift was solid and the car didn't want to start.
In the dashboard, the number of the gear selected was a 8 barred.
So I decided to buy a VCM II clone from obd2tool to read the DTC.
I saw an error code (P0810) about a "clutch postion error" in the TCM so
I decided to reprogram this module. IDS v91.01 said me that a new
calibration file (2S6R-7P170-AD) is available and it will upgrade the
TCM.
But at the end, it displays me an error (0 -0x0 851082).
But after that the TCM doesn't want to respond and at the dashboard the number of the gear selected is now a double-dash.
I ask for some help to restore this TCM or flash the PCM.
I think that my TCM is dead or need a reflash, or the two things.
In some forums, people says that to reactivate ECUs, the solution is to send "as-build" data, which you can retrieve only at ford motorcraft service, after paying a subscription.
Maybe some people here can help me.
thanks.
rex647
Mar 6, 2022 06:20 AM
Marino
Sep 12, 2015 11:10 AM
28
Sep 8, 2015 07:10 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
