zvh
Old Nov 17, 2014 | 08:56 PM
nikki.n.tom's Avatar
nikki.n.tom
Default zvh
what would cause an engine to smoke after about 5 to 10 minutes of running smoke bellows out of the exhaust. new turbo fitted, valve stem oil seals done. there is no smoke on start up at all. any help would be great
Old Nov 17, 2014 | 09:44 PM
Chopshop85's Avatar
Chopshop85
What colour is the smoke?
Old Nov 17, 2014 | 09:58 PM
nikki.n.tom
Think is grey/white.
Old Nov 17, 2014 | 10:06 PM
mgtkr1's Avatar
mgtkr1
sounds like turbo seal. mine has been doing exactly the same thing. does it go away after a run?
Old Nov 17, 2014 | 10:12 PM
nikki.n.tom
No mate once it's warm it's constant smoke. It had a new turbo from cr turbo and did not change.
Old Nov 17, 2014 | 10:17 PM
beaver rs 88's Avatar
beaver rs 88
in the garage
Did you drain/flush out the intercooler when you fitted the new turbo? Could be full of oil from the old turbo if the seals had gone on it.
Old Nov 17, 2014 | 10:20 PM
nikki.n.tom
Yes all was taken off when fitting the turbo and checked. Cleaned feed and drain also.
It's had a new felpro head gasket.
Old Nov 18, 2014 | 02:16 PM
Canada1's Avatar
Canada1
Does the grey/white smoke smell like oil or burning antifreeze?
How did you clean the intercooler and all air pipes/hoses?
Possibly be unburnt oil in the exhaust system? Could take a while to burn it off.
Old Nov 18, 2014 | 02:43 PM
clairendave's Avatar
clairendave
Dave not Claire.
what modifications were done to accomodate a breather system when the zvh conversion was done??
Old Nov 18, 2014 | 04:25 PM
nikki.n.tom
All parts washed in parts cleaner the rinsed with water and dried. But to be fair not to contaminated in the first place.
It's bailey oil breather. Breather in back of block.
It does smell but not like oil though.
Old Nov 18, 2014 | 05:20 PM
beaver rs 88
in the garage
Are you loosing any fluids ie antifreeze or oil or are they all stable?
Old Nov 18, 2014 | 05:26 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Grey/white is most likely water (steam), turbo oil seal would be very obviously blue (oil)..... Water will be head gasket, cracked head/block.
mk1turboestate
Dec 2, 2015 08:31 PM
Chas
Oct 5, 2015 07:13 PM
davidfordrs
Sep 23, 2015 02:26 PM
davidfordrs
Sep 21, 2015 04:23 AM
Del gsxr
Sep 19, 2015 05:53 PM
