Mondeo mk2 1.8td idle problem.
Old Nov 15, 2014 | 09:57 PM
Kevin Cappleman's Avatar
Kevin Cappleman
Default Mondeo mk2 1.8td idle problem.
Hi
I have a 1999 W reg 1.8td that until a couple of days ago has been running fine but now has started idling at about 1200 rpm rather than its usual 950.
I'm not very clued up on Ford diesels so would be graceful for any pointers to what could be the cause.
It's the Endure DE engine and a friend seems to think it might be the cold advance solenoid what ever that is lol
Thanks
Kev
Old Nov 17, 2014 | 07:49 AM
Kevin Cappleman
So i popped the bonnet and after ten mins of fiddling around i found the idle control spring on the throttle body has snapped. As I work in a school and our DM teacher is a mechanical wizz he is kindly fashioning me a new spring from a keyring ring as it should be springy enough to do the job.
Cost ten mins of his time and bugger all else lol
Sorted
wowk
Mar 30, 2021 07:49 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Kiran1600E
11
Oct 2, 2015 11:35 AM
The Enigma
Sep 29, 2015 10:31 AM
Sp3no
Sep 27, 2015 07:23 PM
