Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
1.6 tdci slight hesitation
Old Nov 12, 2014 | 12:14 PM
tank1987's Avatar
tank1987
Default 1.6 tdci slight hesitation
Hi all my car is a 1.6 tdci and has a slight hesitation
For quite a while since it started I've changed
Oil with engine flush
Redex
Air filter
Cambelt
Remap
But still there it on acceleration mainly after going fairly quick if you ease off then accelerate again
What could this be, my next plan is fuel filter change but heard this could be a nightmare
Any tips
Old Nov 12, 2014 | 06:42 PM
MikeyRobbo's Avatar
MikeyRobbo
PS3 - MikeyRobbo
Could be anything, my guess would be EGR or DPF. Get it scanned see if anythings logged, as them to do a static regen aswell if you have a DPF.
Make sure you get as much fresh fuel in the new fuel filter as possible before fitting, enough to start it then immediately hold the revs at about 2500RPM for a minute or 2. If it wont start get someone to give you a tow start.
Old Nov 13, 2014 | 04:24 PM
tank1987's Avatar
tank1987
Thank you it's has egr blank fitted this problem was there before fitting and no dpf I was very lucky
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
The Enigma
Sep 29, 2015 10:31 AM
mondeomark
Sep 28, 2015 06:28 AM
Sp3no
Sep 27, 2015 07:23 PM
