Cosworth parts
RED 2WD AND 4X4 CAM COVERS FROM £135
T5 FIFTH GEARS £120 EACH
LOCKWOOD WHITE DIALED CLOCKS £55
WHITE DIALED CLOCKS NOT LOCKWOOD £45
BLACK CAM COVER £135
4X4 KONIS £175
SET OF 4 LATTICE WHEELS £225
GENUINE 3 BAR MAP SENSOR £150
ORIGINAL GREEN CAM CVER £145
SWIRL POT £65
RED SAMCO BOOST HOSES £70
ESCORT COSWORTH CAM BELT COVER £85
SET OF 403 GREYS £150
WINDOW SWITCH £17.50
GOOD CARRELLI HEADLIGHTS £60 PAIR
STAGE 3 ECU LEVEL 6 £185
CLEAR INDICATORS £20 PAIR
CLUTCH FORK COVER £20
2WD CAM BELT COVER £55
4X4 WING BADGES VERY GOOD £35
FOG LIGHT SURROUNDS £35
REAR DOOR COVERS £35 PAIR
LEVEL 8 ECU STAGE 1 £275
GOOD MOTORSPORT BLUE HT LEADS £55
2WD PLASTIC HEADER TANK £85
FACE LIFT 4X4 DASH (SMALL CRACK ON TOP) £35
VERY GOOD 3DR HEADLIGHTS £100
T34 SILICON BOOST HOSES £35 EACH
PF09 THROTTLE POSITION SENSORS £75
CONE AIR FILTERS £55
SMALL SWIRL POT £60
4X4 KONIS £175
SWIRL POT £65
SMALL SWIRL POT £60
3dr cossie
11
Dec 21, 2015 03:38 PM
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
