saphire cosworth fuel filter leaking
Old Nov 1, 2014 | 08:50 PM
sharpercarper123's Avatar
sharpercarper123
Default saphire cosworth fuel filter leaking
got a problem with my saph after changing fuel cradle and fuel filter i carnt stop it from leaking even after trying numerous copper washers anybody had this issue its burning my head out
Old Nov 2, 2014 | 08:41 AM
cossiestu's Avatar
cossiestu
Is there any corrosion / shit on the banjo itself?
Old Nov 2, 2014 | 11:21 AM
sharpercarper123
no shit or rust on face of banjos carnt understand it tried more washers this morning really cranked them down still leaking????
Old Nov 2, 2014 | 11:37 AM
RichieST's Avatar
RichieST
Think this might be your problem, you only really need to nip them up to get a good seal, any more and it will deform the washer too much and it won't seal properly.
Old Nov 2, 2014 | 12:01 PM
botters's Avatar
botters
competant bodger
take the washers off and heat them with a blow lamp until they are cherry red, allow then to cool. they will now be nice and soft. when you fit them just nip them up do not overtighten them and they should then be fine
Old Nov 2, 2014 | 09:30 PM
sharpercarper123
cheers chaps for replys i will try heating the copper washers up tomoz with a blow torch see if that works
3doorcozmess
Aug 21, 2015 11:17 AM
ekjim
Aug 17, 2015 08:57 PM
Aug 14, 2015 07:29 AM
RSMK4TURBO
Aug 13, 2015 08:06 AM
muffster
Aug 12, 2015 08:14 PM
