Can I mount catch tank behined wing?
Old Oct 29, 2014 | 10:10 PM
jon_d_h's Avatar
jon_d_h
Default Can I mount catch tank behined wing?
I'm building a mk2 escort with a Cosworth engine in it. I'm trying to keep the engine bay tidy so want to mount the catch tank somewhere it cannot be seen. There is space for it between the the wing and side of bulkhead/inner wing. I have 2 pipes in top from engine and one it bottom back to dump then a large hole in bottom which I believe to be a breather for gasses to escape.
Any problems with me mounting it here? It won't catch the wheel, just I don't know if any oil comes out them greater hole which could go on the tyre.
Thanks
Old Oct 29, 2014 | 10:17 PM
jon@work's Avatar
jon@work
find yourself a genuine WRC breather - they mount directly onto the engine block
Old Oct 29, 2014 | 11:46 PM
botters's Avatar
botters
competant bodger
as above, will pedley does these type of breathers he has just done one for a mates escos and to look at it under the bonnet you would think it was factory but its got breathing capabilities for 600bhp plus!
Old Oct 30, 2014 | 06:18 AM
jon_d_h's Avatar
jon_d_h
They do look the part but a bit steep in price so considering a have a proalloy one already, I would prefer to use this one. I can't think of any issues if I mount in behined the inner wing???
Old Nov 3, 2014 | 11:06 AM
jon_d_h's Avatar
jon_d_h
Anyone?
Old Nov 3, 2014 | 11:09 AM
SBT83's Avatar
SBT83
Not Crazy, just Unwell
I'd say it would be fine as long as you can get to it if need be, but if your running it back to sump you should be fine imo
155lee
Oct 27, 2015 04:55 AM
rsguy
44
Sep 29, 2015 03:29 PM
mpilk
Sep 27, 2015 09:21 AM
