MK2 Cossie conversion/cosworth parts
Greens+3BAR Sensor+Grp A Coil +STG3 L6 ECU £350
Standard Inlet £100
4x4 Inlet Blue injectors with fuel rail which includes the dash 6 fittings £400
2wd Exhaust Manifold £250
2wd Water Pump
T3 Turbo unit would be ideal for an exchange unit
Cosworth original engine mount
Brand New 2wd Original Gearstick £150 Rare item
Ignition booster
Thermostat housing unsure if 2wd or 4wd
World cup X member to Pinto/Cosworth Engine Mounts £25
Located in Aberdeen
Email c12rst@hotmail.com
Can arrange delivery on some of the smaller items. Preferred if collect larger items but can discuss.
Standard Inlet £100
2wd Water Pump
Ignition booster
Located in Aberdeen
