comp brake pedal box
Old Oct 19, 2014 | 09:26 PM
binks101's Avatar
binks101
Default comp brake pedal box
Hello all as above anyone using them are there any good?
Old Oct 21, 2014 | 08:56 PM
jamie956's Avatar
jamie956
My experience of them is not good, poorly made and not very well engineered.
Admittedly I have altered an escort one to fit in my Cortina but that's only the mounting points, had loads of issues getting clutch to work with crap pedal ratios and brakes are poo which I also put down to the pedal box.
Old Oct 21, 2014 | 09:44 PM
binks101's Avatar
binks101
Not good then mate:/
Old Oct 21, 2014 | 09:57 PM
binks101's Avatar
binks101
What other companies sell decent pedel boxes??
Old Oct 22, 2014 | 04:59 PM
jamie956's Avatar
jamie956
What car is it for,
Old Oct 22, 2014 | 05:02 PM
paul16v's Avatar
paul16v
Monte 087
Tilton make very good pedal boxes, avoid compbrake/obp cheap tat.
Old Oct 22, 2014 | 06:17 PM
andy escos's Avatar
andy escos
I had a comp brake pedal box and they are crap the pedal ratio was 3.5 to 1 which is bad Tiltn do excellent pedal box,s which are upto 6 to1 which is very good
Old Oct 22, 2014 | 08:03 PM
binks101's Avatar
binks101
Originally Posted by jamie956
What car is it for,
3 door jamie
Old Oct 22, 2014 | 08:05 PM
binks101's Avatar
binks101
Cheers Paul and Andy will look them up!
Old Oct 22, 2014 | 08:26 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Got both my Tiltons via these guys: http://www.competitionsupplies.com/tilton
Good advice and top service
Old Oct 22, 2014 | 08:54 PM
jamie956's Avatar
jamie956
3 door jamie
I think unless your doing an all out race car changing the pedal box can be a lot of hassle for not a lot of gain. I don't think any of the tilton boxes are going to be a straight swap there likely to need a fair amount of fab work to fit.
Old Oct 23, 2014 | 08:45 PM
binks101's Avatar
binks101
doing all the fab work now jamie like roll bar mounts engine mounts etc some making a bulkhead mount shouldn't be a problem
Old Oct 26, 2014 | 11:48 AM
Sonic Boom's Avatar
Sonic Boom
I have to say I got excellent service from CompBrake after speaking to David @ the Autosport show at the begining of the year.
I was after a dual master cylinder setup which bolted in place of the original ABS master cylinder which they did for many other cars off the shelf but not the Sierra.
He said no worries send me a ABS unit and I'll copy the bolt pattern and make you a custom one which he did for no more money than a stock item.
You can now buy a sierra one from CompBrake
And it's been faultless all season so much better than ABS setup.
Rich
Old Oct 26, 2014 | 11:59 AM
markk's Avatar
markk
With Compbrake it does depend on who you deal with.
Old Oct 26, 2014 | 05:34 PM
Sonic Boom's Avatar
Sonic Boom
Here's a couple of photo of the my Dual Master Cylinder setup from CompBrake before I fitted it:
Rich
Old Oct 26, 2014 | 06:00 PM
matthewpickup's Avatar
matthewpickup
I bought one , a direct replacement .... there was nothing direct about it , my brakes are crap and would cause you to crash , I called them and asked about fitting , and if they would do the job , and after giving them around £500 I am now taking it back out as its no good , I have no idea how they get away with selling this , trading standards wants to be giving them a talking to as its not as they say .
Old Oct 26, 2014 | 06:10 PM
Sonic Boom's Avatar
Sonic Boom
The same as mine above?
Rich
Old Oct 26, 2014 | 06:20 PM
matthewpickup
no not the same at all , which is strange but maybe its so they could say its direct replacement , as its basically just a standard peddle box modded to have the two master cylinders and balance bar
Old Oct 26, 2014 | 06:27 PM
Sonic Boom's Avatar
Sonic Boom
What you want is what I had above mate, it does just bolt straigh on you don't have to touch the pedals at all other than to disconnect the old rod and connect the new one.
Rich
Old Oct 26, 2014 | 06:32 PM
matthewpickup
yea that was the kind of thing I was wanting , how much was it if you don't mind me asking?
Old Oct 26, 2014 | 07:06 PM
Sonic Boom's Avatar
Sonic Boom
With the box, both master cylinders, in car adjuster, 2 x pots with remote lines and brackets £300 all in
Rich
Old Oct 26, 2014 | 10:42 PM
matthewpickup
Rich
that's good , wish I had seen this before nevermind I know now
thanks
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
