Changing Pulleys from V to Multi V?
Old Oct 19, 2014 | 03:01 PM
Sonic Boom's Avatar
Sonic Boom
Default Changing Pulleys from V to Multi V?
Currently I have my 3 Door setup as standard with single V pulleys and belts.
But it keeps throwing and flipping them over at high revs (a common problem i'm lead to believe)
Can I just change to multi v pulleys and belts like the 4x4 setup but keep the orientation of my PAS Pump and Alternator as standard 2WD?
Will they still line up?
Can can you tension normally with the PAS pump and alternator lever action rather than fitting a sprung tensioner?
Cheers Rich
Old Oct 19, 2014 | 10:38 PM
markk's Avatar
markk
No, you need all the 4x4 brackets etc, non are the same, I fettled mine with a grp a bracket and no have an adjuster
Mark
Old Oct 26, 2014 | 11:49 AM
Sonic Boom's Avatar
Sonic Boom
Mark
Is it the offset of the pulleys so they wont line up?
Cheers Rich
Old Oct 26, 2014 | 11:56 AM
markk's Avatar
markk
Yes it is
Old Oct 26, 2014 | 12:43 PM
Sonic Boom's Avatar
Sonic Boom
So I could make some shims up then?
Cheers Rich
Old Oct 26, 2014 | 12:53 PM
markk's Avatar
markk
I suppose so
gambo08
Feb 4, 2016 10:49 PM
Nov 1, 2015 06:53 PM
dojj
Sep 29, 2015 10:32 PM
rsguy
44
Sep 29, 2015 03:29 PM
