Big spec 4x4 sapphire cosworth
Old Oct 18, 2014 | 07:59 PM
jonny's Avatar
jonny
Default Big spec 4x4 sapphire cosworth
91 J plate non cat car,white with black leather,74,890 miles with lots of history,stamped books, mot's, bill etc,8 previous owners.Full engine rebuild in the winter of 2012/13 by myself and all machining done by olli at nms. Brief spec 200 block torque plate board block to 0.5mm oversize and refinished with a plateoux hone to give a 2 inch skirt to bore clearance, the deck face has been machined. Crank ground to 0.5mm on mains and big ends. Replacement of the little end bearings in the con rods and re machining of these to suit mahle pistons. Machining of piston to give 7.5-1 compression ratio and value cut outs put in. Head has been ported and rebuilt with new ford stem seals and new hydraulic tappets, head was put together by olli at nms. Big siemens injectors,genuine rs500 t4 turbo moded by nms on 2 wheel drive manifold. Air injectors and live mapped by karl at nms to approx 460 bhp on switchable boost so can be turned down for normal driving , big intercooler, big rad , samco hoses etc 6 paddle clutch,uprated front diff, uprated engine mounts and gear box mount, quick sift on standard box, standard rear diff. The car sits on 17 inch gold comps with yoko tyres, coni shocks, uprated standard ride height springs, stainless exhurst, body work in very good condition , all original panels, mot till may 2015,leather very good all door cards good, fortune spent , £10495, contact 07870272210
Old Oct 18, 2014 | 08:03 PM
jonny's Avatar
jonny
Smile Big spec 4x4 sapphire cosworth
Any question please ask,sorry no px, car is located near Alferton, Derbyshire. Don't know how to post pics , can email on reqest or could someone kindly put them up for me , many thanks.
Old Oct 18, 2014 | 08:08 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
https://passionford.com/forum/pictur...otobucket.html
SmudgerByName
52
Jul 28, 2016 06:14 PM
lukeeboy149
Aug 22, 2015 04:29 PM
155lee
14
Aug 22, 2015 12:15 PM
cossynut2
Aug 19, 2015 11:29 AM
yawiejon
Aug 10, 2015 08:12 PM
