mk2 RS standard front brakes
After a small favour,
Can anyone with a mk2 still running the standard brake setup take a measurement for me? I need to know the distance fron the centre of the hub nut, across the disc and caliper to the furthest point of the caliper. Approx with the wheel on the car should be ok?
2x this figure giving me the minimum inner diameter of the wheel.
Basically i want to know if they will fit behind 17's.
Thanks
Thanks
