Thermostat Choices on a ZVH?
Old Oct 7, 2014 | 09:35 PM
Chas's Avatar
Chas
Default Thermostat Choices on a ZVH?
Forgive me for all of the questions. I have tried Google and searching although the questions seem not be quite what I want.
I am debating whether my car is running a thermostat at the moment. Whilst my heater is warm the temp gauge is quite over the place! The fans however do cut in and cool the car down in addition to it gradually getting warmer in traffic as opposed to straight away. My setup at the moment is an Airtec radiator with a Bailey swirl port and Stainless header tank.
What thermostat do you chaps recommend for a ZVH? Is my only choice an 88 degree item? (I am not going to lie, that seems to look a little hot for my liking!).
Old Oct 7, 2014 | 09:38 PM
studabear's Avatar
studabear
Not a zvh, but my zetec turbo has a cvh thermostat housing fitted, with a standard rs turbo thermostat.
Old Oct 8, 2014 | 11:02 AM
haz87's Avatar
haz87
Run a 82 deg in mine
Old Oct 8, 2014 | 05:01 PM
Karlos G's Avatar
Karlos G
Balls Deep!
The ideal temp for thermal efficiency is around 90c so a standard one is fine.
Old Oct 8, 2014 | 06:30 PM
Chas's Avatar
Chas
Okie doke, cheers for the input chaps. I may be going stock.
On the basis that I have a ZVH (it doesn't seem to overheat in traffic) with an Airtec rad and a chargecooler radiator which covers half of the radiator (it is not as bad the intercooler items) would you still go for an 88 degree item? I am aware that people with the Airtec intercoolers tend to run cooler thermostats since it is felt by some that they can promote hotter running.
Studabear I take it yours is also running an 88? Is it OK around town etc.? Normally I would not be so picky but a previous car gave me enough cooling issues to last me a lifetime.
Old Oct 8, 2014 | 08:31 PM
s1cab's Avatar
s1cab
Don't forget that with antifreeze boiling point is around 115-125°c. So it's not that bad running close to 90-100
Chas
Oct 5, 2015 07:13 PM
The Enigma
Sep 29, 2015 10:31 AM
little bram
Sep 27, 2015 07:45 AM
davidfordrs
Sep 21, 2015 04:23 AM
