Cars & Parts Wanted. Need a specific car or part? Ask in here!! Starting a topic requires you to have purchased a gold membership.
WANTED Escos rear N/S outer cv joint
Old Oct 1, 2014 | 05:03 PM
andy2577's Avatar
andy2577
Default WANTED Escos rear N/S outer cv joint
As per title I'm after a outer cv joint on te N/S (passenger) with abs ring
Way to tell is it has reverse thread I.e to loosen you rotate it clockwise
Pic is of the joint I need
Attached Thumbnails WANTED Escos rear N/S outer cv joint-shaft.jpg
Old Oct 7, 2014 | 05:26 PM
RIB1122's Avatar
RIB1122
do you still need one?
moesin2005
Jan 23, 2022 06:28 PM
3i Jim
Nov 20, 2015 05:12 AM
james kiely
Aug 28, 2015 08:58 PM
track.focus'd
Aug 12, 2015 05:53 PM
adriansaleem
Aug 3, 2015 11:21 AM
