Cosworth 6 Degree Beams & Suspension Parts
Old Oct 1, 2014 | 05:03 PM
MT-Motorsport's Avatar
MT-Motorsport
Default Cosworth 6 Degree Beams & Suspension Parts
MT-Motorsport 2wd 6 Degree Fully Adjustable Rear Beam.
A great upgrade for any Cosworth, all rose joint and spacers are new, high tensile zinc plated bolts with nyloc nuts. Freshly powder coated inhouse.
On Stock ready to go.
£1300
MT-Motorsport 4x4 6 Degree Fully Adjustable Rear Beam.
£1300
Old Oct 1, 2014 | 05:07 PM
MT-Motorsport
Cosworth WRC - Group A Front Anti Roll Bar Set-Up (New)
All parts are brand new and have been anodised, zinc plated and powder coated.
£650
james kiely's Avatar
james kiely
fairplay mark ,that looks very nice
Old Oct 1, 2014 | 05:08 PM
MT-Motorsport
Cosworth WRC - Group A Rear Anti Roll Bar Set-Up (New)
£650
Old Oct 1, 2014 | 05:10 PM
MT-Motorsport
Cosworth Group A Front Anti Roll Bar Brackets (New)
£70
Old Oct 1, 2014 | 05:11 PM
MT-Motorsport
Cosworth WRC - Group A Rear Anti Roll Bar Brackets (New)
£70
Old Oct 1, 2014 | 05:12 PM
MT-Motorsport
Cosworth WRC - Group A TCAs (New)
£650
Old Oct 1, 2014 | 05:15 PM
MT-Motorsport
WRC - Group A Compression Struts (New)
£450
Old Oct 1, 2014 | 07:44 PM
Caddyshack's Avatar
Caddyshack
What does the 6 degree bit actually mean and for road use is there much benefit...if so what?
Do the supra diff kits fit these as normal (on the 4x4 ones)????
Are they any noisier on the road i.e. noise from the bushes?
Old Oct 2, 2014 | 07:36 AM
jaimesdna's Avatar
jaimesdna
How much are your supra diff conversion kits & do you keep them in stock
Old Oct 9, 2014 | 04:37 PM
Caddyshack's Avatar
Caddyshack
No reply to this???
Old Oct 9, 2014 | 09:08 PM
throttle jockey's Avatar
throttle jockey
No reply to this???
Just do a search on 6 degree beams and there are many posts on them that explain the details.,and they are awsome mod if you drive your car properly,very simple but effective mod if not set up properly make it awfull I have them on both my cars and they greaaaat when set up to mr rainbirds settings these ones have more adjustment on the outer arm than mine so you can place wheel more central in the Arch great value these.
Old Oct 16, 2014 | 02:26 PM
Caddyshack's Avatar
Caddyshack
Thanks, I will do some searching as suggested. I had the geometry changed on my 911 a lot for track use and ended up with a mirror image of the setup that Paul Edwards used to win the Porsche Cup Challenge so very aware of how critical it can be and the benefits. Clearly track use is where the focus normally arises but I dont plan to track this car so I will mainly be looking for a road car setup. To be fair my Pug Cossie seems to handle pretty well but I would like to take it to a wet handling place to see what it does over the limit which would be silly to do on the road. I went to Mira in my Cerbera and was amazed at how good it was compared to the 355 Rari we took with us!
Oct 9, 2015 07:38 PM
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
dal3door
Aug 13, 2015 06:55 AM
Old ford
Jul 31, 2015 06:50 AM
