Best actuator for 400/450bhp cossie
Old Sep 27, 2014 | 07:47 PM
3drRich's Avatar
3drRich
Default Best actuator for 400/450bhp cossie
Just looking to see what others went for in terms of actuator. My car should be between 400 & 450 bhp running a t38.
Old Sep 27, 2014 | 07:51 PM
James @ M Developments.'s Avatar
-31 would be fine, bigger back ends don't really warrant a strong spring as there is less exhaust pressure, but it does depend on many variables, i.e. what boost control you choose etc etc
Old Sep 27, 2014 | 08:10 PM
The Youth.'s Avatar
The Youth.
As james said, mine was set up perfectly at msd and runs a T38, air injector, -31 and holds the boost perfectly, 32 psi down to 27 at the limiter gave me 455 bhp
The air injector made the boost so much more stable than the old t34,-34 amal valve set up
steve
Old Sep 27, 2014 | 08:45 PM
3drRich's Avatar
3drRich
Cheers guys. James if I order one from you guys what do I ask for just a -31 actuator?
Old Sep 27, 2014 | 08:53 PM
yes, we have different lengths so you need to know what you want though, should be a medium one if its the 3dr
Old Sep 27, 2014 | 09:05 PM
3drRich's Avatar
3drRich
It will be for my 3dr yeah.
Old Sep 27, 2014 | 09:26 PM
BRAMMER's Avatar
BRAMMER
Mine ran a -34 from mapping at MSD but there must have been a reason
Old Sep 28, 2014 | 03:08 PM
cossynut2's Avatar
cossynut2
10 Year Member
My 2wd Sapphire engine specc sounds pretty much the same as yours and it has the -31 which works well.
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
