Electronic Brake Boosters
Hello All,
I'm wondering if anyone has used an Electronic Brake Booster or knows where I can get one similar to this..
http://www.ebay.co.uk/itm/Electric-V...item3f3a874a64
It wouldn't matter if it wasn't a generic one, I know a few BMW's and Volvo's that use them so I could make something work.
The Hayabusa engine in the project car won't generate the vacuum needed for the brake so I'm thinking of installing an electronic one.
Thanks in advance.
Thanks in advance.
I was looking at these
http://www.simtekuk.co.uk/index.php/...mp_kits/?k=:23::
Other way is to use a alternator with a vacuum pump attached,
http://www.transitcenter.co.uk/shop/...5d-1986-1997-2
I've found these on ebay.. http://www.ebay.co.uk/itm/HELLA-REPL...item233cebff68 ..
As you can see they don't come as a kit where as SimtekUk have all the pressure switches and relays etc. I'll probably go for something like VAC-002, not cheap but they are your brakes after all
Yes its a good kit, i have seen home made set ups using a small resevoir tank and a vachuum swith to control a pump but to be honist getting it all to work could be a pain in the arse, like you say do you really want to mess about with brakes.
