ford focus st170 turbo project
If I was turbocharging an st170 I'd drop a Will Pedley a message. He knows pretty much all there is to know about these engines.
The St170 gearbox uses a different spline to every other Ford gearbox. You need to order the paddle clutch conversion from America but it's expensive. I do remember vaguely hearing Helix were making one though, so might be worth a try.
Without costing an arm and a leg its cheap to convert to 2.0 focus setup.
2.0 flywheel
what ever 2.0 clutch you want.
2.0 gearbox
2.0 gear linkage
2.0 gear stick.
(its is smiple bolt on job and basicly all the same you would have to do just changing the clutch just with extra 20 mins work)
2.0 flywheel
2.0 gearbox
2.0 gear linkage
2.0 gear stick.
Palethorpe01
15
Aug 18, 2015 06:09 AM
track.focus'd
Aug 12, 2015 05:53 PM
gordyshreds
20
Aug 10, 2015 02:59 PM
