Electric fan wiring
Old Sep 21, 2014 | 07:57 PM
mk22door's Avatar
mk22door
Fart of the Purniture
Default Electric fan wiring
I've bust the viscous fan on my pinto removing it from the old coolant pump, so new pump fitted and I'm going to fit an electric fan instead.
I found these spools of wire in an old Granada a few years back, will it be okay to use on the electric fan?
For now i'm just going to wire the fans up to a switch so I can turn them on and off at will. done this before but had old bits of engine loom so I knew it was okay.
Is this stuff above up to the job?
Old Sep 21, 2014 | 08:02 PM
mk22door's Avatar
mk22door
I'm really not up on gauge correctnesssss sss'
Old Sep 21, 2014 | 08:05 PM
mk22door's Avatar
mk22door
it's to do with Amps required vs length of the wire, I think?
Old Sep 21, 2014 | 08:39 PM
stevieturbo's Avatar
stevieturbo
C**t
It would be rather on the small side for a fan, fans can draw a fair bit of current.
Old Sep 21, 2014 | 08:44 PM
mk22door's Avatar
mk22door
Okay, thanks for the reply.
Appreciate it
Old Sep 21, 2014 | 08:53 PM
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
wire should be copper and at least 1.5,
I always wire in a relay and a fuse too 20-25 amp
Old Sep 21, 2014 | 09:21 PM
mk22door's Avatar
mk22door
That's great advice
cheers
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
stevecfrst1
Sep 30, 2015 05:18 AM
IainRS1700T
Sep 25, 2015 06:44 AM
