tdci performance on the cheap
Old Sep 21, 2014 | 09:51 AM
jabbiss273's Avatar
jabbiss273
Default tdci performance on the cheap
Hi all new here i've a 02 zetec s estate tdci. Now firstly ive got a whole load of boost leaks from the hoses I keep repairing them with a layer of duck tape then plaster board scrim tape then more duck tape. Which lasts for a while but now I'm bord of it n want to change them does anybody know where to get the cheapest silicone full set from? Secondly I want more POWER besides just a good old service. I gather the egr blank n inlet clean helps. But is there owt else that help performance either just elbow grease or cheap parts. And then finally are re maps a good choice. I'm worried about my flywheel, a mate started driving a 115 hard and the dual mass gave up n took the rear main oil seal, starter motor,, caused a gearbox whine n took a day to get the flywheel off.
Old Sep 23, 2014 | 12:23 PM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
Sort the hoses out as soon as you can tape won't fix them as there is a LOT of pressure that goes through them - leaking hoses will do the turbo no favours. eBay seems to the cheapest place to get silicone ones.
Definitely blank the EGR - on an 02 Mondeo it will cause no issues at all, and will improve the car.
If you want more power, a simple remap will work wonders - but if the clutch/DMF is tired it will finish them off. If they've been replaced not to long ago then they can take the increase in power without any issues.
Old Dec 27, 2014 | 12:09 PM
gunscrossed's Avatar
gunscrossed
I'm looking in to moding mine, from what I've read.
In order f cost,
EGR blank
Panel filter
De-cat
Bigger intercooler
Re-map
The first three cost less than £100?
mark94
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
