Propshaft and rear diff question
Old Sep 19, 2014 | 12:32 PM
Non custom's Avatar
Non custom
Default Propshaft and rear diff question
Just a quick question really for the gurus out there
Been out of the cosworth world for quite some time now so memory rather faded
Will a std sapphire propshaft eg normal pinto type fit into a cosworth t5 box or are they different ?
Also will a cosworth 2wd prop mate to a 4x4 rear diff or is the input flange different ??
Just gone to fit my t5 box and the prop won't go in and rather awkward trying to measure and count splines from under car
Think I have a 4x4 7" rear diff and shafts but should be 2wd and god knows what propshaft as wont fit into tail end of the t5
Old Sep 19, 2014 | 02:19 PM
Marc sierra's Avatar
Marc sierra
I am not sure on the gearbox side of the prop. But I guess it will be different as the normal Pinto has a T9 box. For the MT75 box it is definately different. On the diff side all prop connections are the same for all Sierras.
Old Sep 20, 2014 | 12:01 PM
Non custom's Avatar
Non custom
Cheers fella think the car has a different prop fitted it seems but thx for the reply
Old Sep 20, 2014 | 12:25 PM
martysmartie's Avatar
martysmartie
The props are different for obvious reasons (i.e. stronger, as a standard one would snap) so irrespective if the fitment is the same, you would not want to use a standard one.
The 4x4 drive shafts push in, 2WD are bolted.
Martin
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
cossirob
Sep 3, 2015 09:17 PM
turbowag
Sep 3, 2015 08:07 AM
