Collins Pro monitor 4x4 loom
Collins monitor only 3 months old its a secs monitor on steroids ! this is the pro version if you can buy a new one these retail at £385 delivered
The monitor is available as a standard version and also as a professional version (the standard version is priced above). The monitor displays real-time engine management parameters, these include: Engine RPM (rpm), Coolant Temperature (ºC), Charge Air Temperature (ºC), Boost Pressure (absolute) (bar), Battery Voltage (V), Throttle Position (º), Ignition Timing (º BTDC), Fuel Injector Opening Time (mS), Sensor Fault Detection, 4 channels of analogue data (optional), Current Ignition Map Address (Professional Version only), Current Fuel Map Address (Professional Version only), Blanket Fuel Adjustment (Professional Version only), Blanket Ignition Adjustment (Professional Version only), The monitor works with ‘Ford Cosworths' that run the Magneti Marelli L6, L8 or P8 ECU if the correct Powerchip / Pectel chip is also fitted. So this includes all ECUs running Pectel / Collins boards (the comms support may need enabling, which we can do for a small charge on L8s, but some P8s may need a £50 mod to the board). Having spoken to MSD, I am lead to believe that some of their software also supports this, but you would have to confirm with them
Its a brilliant gauge to have as with sensor checking and tps setup ect
£240 posted
4X4 Loom in great order the loom separates as it should do as when these looms get old the 3 bulk head plugs corrode together and cause running issues but this one is all ok
£130 posted
£240 posted
£130 posted
