air charge temp sensor wiring help
Sep 15, 2014 | 08:54 PM
hi everyone. just a quick question if someone can help! on the air charge temp sensor in the inlet manifold, its a 2 pin plug but what colour wire goes to what side of the plug for the sensor ? as i need to put a plug on! a picture or answer would be a great help please.
Sep 15, 2014 | 09:37 PM
Im pretty sure it wont matter which way round the wires go as it only measures resistance on temp rise/fall
Sep 16, 2014 | 07:24 PM
Quote:
Originally Posted by
cossie330
But it will read backwards if it's the wrong way around ?? As the wires go to 2 different pins at the ecu ?
Sep 16, 2014 | 07:36 PM
Im sure as it only measures resistance it wont matter, but perhaps someone else could clarify
Sep 17, 2014 | 07:46 PM
I hope so. Does nobody have a cosworth loom to hand?????
Sep 17, 2014 | 11:11 PM
luke_rs1800
I'm with him, i.e. it does not matter, as it's simply a thermistor (so not polarity conscious)
Martin
15
Oct 7, 2015 03:43 PM
Kam B
Sep 24, 2015 10:40 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
mike elsome
Sep 14, 2015 04:08 PM
Ben26
Sep 3, 2015 07:55 PM
