rear swinging arm bushes on ford ka 2004
Old Sep 12, 2014 | 01:31 PM
hoggie31's Avatar
hoggie31
Default rear swinging arm bushes on ford ka 2004
can anybody tell me how to replace swinging arm bushes on ka and is there a right and wrong way to fit them. i just brought a pair off ebay from autoparts.
Old Sep 12, 2014 | 03:24 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
drill/burn out the rubber, hammer and chisel out the metal surround. clean up and press in the new ones.
Old Sep 12, 2014 | 07:04 PM
Churtz's Avatar
Churtz
Small chisel down the side between the bush metal casing and the arm. Smash it through. Then the bush can be hit out.
Getting the new ones in can be a pain without the right tool. You can make a tool with 2 sockets and nut and a bolt. Similar to this....
http://youtu.be/QKhRfSMd5WY
matt.
Old Sep 12, 2014 | 07:06 PM
Drill the rubber out tthn this will leave the other outer metal part of the bush. Get a hack saw and cut the metal part then chisel it out.
Old Sep 22, 2014 | 06:40 PM
hoggie31's Avatar
hoggie31
thank you for all your replies, your method worked a treat and yes ,they were a pain to get new ones in but worth the struggle in the end.
TrevCos
Aug 17, 2015 09:08 PM
155lee
Aug 14, 2015 11:21 AM
track.focus'd
Aug 12, 2015 05:53 PM
