Sierra cosworth 3dr rolling shell + orignal RS500 bumper/spoiler
500bhp Cosworth in making
It hurts me to do this but it is not getting used let me list what it has got.
I got this as a texaco rep many moons ago and was turning into a road but mainly track car.
1987 Sierra Cosworth
3dr shell with no rot/rust underneath
Original RS500 front bumper and rear spoilers and grill
Adjustable TCA (which have not seen the road just been on car)
Gaz coilovers front and back again not very old
Cosworth diff and prop are included and fitted to car
Compression struts are also fitted.
Flocked Dashboard
Manual Steering rack as it was going to be a track car so now runs quaife non pas rack
Roll Cage inside, rear part is welded front is bolted
Omp racing steering wheel
i have full car loom in a sack so is there if you want it.
what it needs to get back going.
Engine/Gearbox/ancillaries.
fuel tank pipes/loom etc
interior there is none in apart from the dash
brakes
The engine bay has been smoothed and sprayed so is like new just a bit dirty at min. once car is polished it really does shine.
inside has been sprayed aswell
rear wheel well has been taken out and plated over(if your really fussy you can put a new one in)
Bulkhead were servo goes has been adapted for pedal box and hydraulic clutch but again can be easirly changed.
negatives
3 slight bubble spots on front wing (nothing for a bodyshop and they havent got bigger in all the years i have had it.
front bumber has crack in but again easy repair and its a original rs500 item with aftermarket splitter.
I know how much the bumper and spoiler goes for so taking that in consideration i think its well priced.
I have owned the car for around 6-7 years
the stickers will come off ok as they havent seen road since been put on.
here is pics before it come off the road.
remember it dont come with these wheels/exhaust now they are rolling on crappy 16" for cossie rep wheels.
if you have a rotten cosworth the running gear can go straight in and you have a good car with little effort and worth a fortune.
This is a Very clean example not sill problems at all. and been stonechippd inside and painted black.
£4800 firm
Email roosiesport@gmail.com
Call/Whatsapp/Text 07876540500
Car is located in Brandon (Suffolk/Norfolk border)
can deliver for .80p mile but would need payment for transport up front and agreed before hand.
its hard to get hold me during day due to no signal at work but im available on email/whatsapp throughout the day.
no messers or dreamers ill try get some updated pics but nothing has changed on outside apart from wheels and no exhaust
Flocked Dashboard
brakes
negatives
£4800 firm
After about dozen enquires i think ive got back to most of you.
Should of stated in advert sorry
yes its a original Cosworth on logbook.
I will get some pics as it stands at weekend once i give it a clean.
charliecosworth
Aug 19, 2015 02:00 PM
155lee
Aug 14, 2015 11:21 AM
