Cosworth battery in boot
Old Aug 28, 2014 | 08:04 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Default Cosworth battery in boot
Who's done it? Did you use an open type battery box or closed type? Also have you ran the cable inside or outside the car and what size fuse did you use? I'm thinking of using a 180amp one. (Put an amp clamp on a sprinter and that pulled about 180ish on start up). Also did you fit a central earth point under the bonnet if so any pics.
Old Aug 28, 2014 | 08:36 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
This is how it was a few years back Andy. Pre-cage behind rear seat next to WI tank & Screenwasher bottle.
No Fuse the cables run in car to Insulated Terminals through the Bulkhead. You simply use the 2 terminals on the bulkhead as you would the normal Battery Terminals. Any Fuses come after that. Im looking for pictures of that at the mo.
Old Aug 28, 2014 | 08:48 PM
ajamesc's Avatar
ajamesc
Cheers rod I'll have to do a little jiggling about on mine as I've a swirl pot and second fuel pump there. I've seen that exact box on eBay so I'll go for that design. I'm only thinking of fusing it at the battery because if that live wire rubs through and sorts out under the carpet or something it will make quite a mess lol
Old Aug 28, 2014 | 08:55 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
You can just see the Terminals on the Bulkhead . In my application the Fuel Pumps & a few other bits are fed to the 16V amplifier shown to supply the vital bits with extra Volts even if the Alternator fails. I would never run a Big Power car without that feature where a Alternator failure can result in engine failure.
Volts.
Old Aug 28, 2014 | 09:13 PM
Thats a good idea Rod.
Old Aug 29, 2014 | 07:17 AM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
I've done a few and always run a fuse at the battery end for the main power lead, every OE application I've seen does the same.
Old Aug 29, 2014 | 07:43 AM
cossynut2's Avatar
cossynut2
10 Year Member
Question
Just as a matter of interest what is fitted in your engine bay where the battery would normally be which means you have to re-locate it in the boot?
Old Aug 29, 2014 | 08:05 AM
ajamesc's Avatar
ajamesc
My breather system is fitted there now
Old Aug 29, 2014 | 08:06 AM
ajamesc's Avatar
ajamesc
What size fuse do you use Martin as I've no idea what the amp draw is on a yb during start up.
Old Aug 29, 2014 | 08:31 AM
turbomook's Avatar
turbomook
That's a very nice breather you have there mate
Old Aug 29, 2014 | 08:42 AM
Martin-Hadland
500 for the main lead and 150 to the fuse box.
I was thinking quite the opposite, I wouldn't be moving the battery to the boot to accommodate it!
Old Aug 29, 2014 | 08:56 AM
turbomook's Avatar
turbomook
That breather was required for my spec engine, so did not have much choice..
It was no problem having the battery in the boot, I managed to hide all the cabling and run a large power cable to the boot.
Old Aug 29, 2014 | 09:02 AM
Martin-Hadland
It may function ok but it does look a bit like a dogs dinner IMHO!
Old Aug 29, 2014 | 09:12 AM
turbomook's Avatar
turbomook
What breather are you using on your car Martin? This is the first breather I had made from Spec R. It sat fantastic in the engine bay and no mods required, but it was pushing oil back through the atmospheric hose. So was told I needed bigger tanks. It could of also been the fact I was not breathing from the cam cover at the time..
Also you don't see the breather as much on an Escort as its tucked up in the bulk head lol. I had planned to powder coat it black, and move the breather filter somewhere with a hose.
Old Aug 29, 2014 | 09:53 AM
ajamesc's Avatar
ajamesc
I'm not looking to argue over breather set ups lol. Everyone has there own way of doing things and you take advise from who you use. I like the breather set up and battery in the boot don't bother me one bit as the car is used purely for fun.
All I'm after is battery box ideas as there is a few to pick from
Old Aug 29, 2014 | 12:11 PM
gcfcos's Avatar
gcfcos
I do like that breather system, it's differant and will stand out in amongst all the ones I've seen at shows, same tanks on every car normally, prob because they work but nice to see a differant set up
Old Aug 29, 2014 | 03:32 PM
cossynut2's Avatar
cossynut2
10 Year Member
Thumbs up
Now see what you have had to move it for, nice looking set up.
Old Aug 29, 2014 | 04:13 PM
ajamesc's Avatar
ajamesc
Yes mate it is I'm chuffed with it thanks again
Old Aug 29, 2014 | 06:32 PM
stevieturbo's Avatar
stevieturbo
C**t
It's very rare for the starter line to have a fuse on it. But if you can fit a fuse that works for you, it would certainly not be a bad idea.
All power to accessory wiring it makes sense to fuse. But bare in mind most of that power comes from the alternator when the engine is running, so a fuse at the battery will only do so much.
A fuse local to the alternator would do no harm either.
All the usual places sell battery boxes of some sort, Merlin, JJC, Demon etc etc
Old Aug 29, 2014 | 06:35 PM
ajamesc's Avatar
ajamesc
Yeah only reason I'm thinking fuse is because it's a constant live running the length of the car under the carpet. If it shorts out it's a fire hazard. Just need a fuse that's not going to blow under starting load or something silly.
Old Aug 29, 2014 | 06:40 PM
stevieturbo
C**t
Yeah only reason I'm thinking fuse is because it's a co stand live running the length of the car under the carpet. If it shorts out it's a fire hazard. Just need a fuse that's going going to blow under starting load or something silly.
Problem with a starter load.
It may draw say 200A, you use a fuse at say 250A....realistically it wont blow until 300A
You could have a small short of only a few amps which could cause that fire risk anyway. So there is a high chance the fuse wont really protect anyway. Now a good solid cut/short, then yes it would likely blow....or the battery itself.
Fuses dont work miracles, but yes they're better than nothing at all
Old Aug 29, 2014 | 06:47 PM
ajamesc's Avatar
ajamesc
I'll have a play about with it. I put an amp clamp on a sprinter and that was pulling about 200 on start up. I've seen the affects of shorted wiring at work twice now. An LF45 road sweeper the driver wired his own interior fan into. He left the wires draped across the foot well that caused the rubber floor to catch fire after shorting and melt the dash. And an older scanina that burnt out after the driver smelt burning under the dash lol
Old Aug 29, 2014 | 06:54 PM
stevieturbo
C**t
Yep, wiring is dangerous, but that fan wiring might only have drawn 20-30A and was a fire risk.
A friend had a rear vent thing fitted to his van years ago for the dogs, the people who fitted it never fused anything and 2 days later the van went up in smoke.
But again low current anyway.
So a 200A or 300A fuse ? Really isnt going to offer the protection you think it might.
use good quality cable, terminations and route the cable as safely and securely as possible.
ie for me that means either inside or at least somewhere not around the perimeter of the vehicle that might be most vulnerable in an accident.
Old Aug 29, 2014 | 06:59 PM
ajamesc's Avatar
ajamesc
Yeah i know what your saying I'll run the live in plastic conduit as I've done with my fuel pump live wiring
Old Sep 1, 2014 | 10:08 AM
gcfcos's Avatar
gcfcos
Maybe put one of those cut off switches with the red key like u see on diggers and some trucks. I got one ready to fit to my saph, at least that way if something happened u could switch the power off and also an extra security feature
Old Sep 1, 2014 | 10:13 AM
ajamesc's Avatar
ajamesc
If you look at my pic there is a battery cut off as I don't use the car that much so the cut off is there to save my battery
Old Sep 1, 2014 | 01:25 PM
Fil's Avatar
Fil
ELASTIC BAND
whilst your at it take a look at Sonic Booms lithium Ion thread
https://passionford.com/forum/ford-s...n-it-runs.html
rog
Aug 31, 2015 04:18 PM
David Potasnick
Ford Fiesta
Aug 22, 2015 10:54 PM
FordJonah
Aug 22, 2015 08:31 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
Aug 14, 2015 07:29 AM
