2wd hydraulic clutch conversion help
Old Aug 24, 2014 | 10:30 AM
luke_rs1800's Avatar
luke_rs1800
Default 2wd hydraulic clutch conversion help
hi everyone looking for some advice when doing a hydraulic clutch conversion on a t5 gearbox using an external slave does the tunnel need modifying at all ? or does it fit ? thanks. luke.
Old Aug 24, 2014 | 10:43 AM
doga-ot's Avatar
doga-ot
Do a search bud there's a how to guide on here
Old Aug 24, 2014 | 11:27 AM
luke_rs1800
thanks mate iv been searching i cant find what im trying to find out tho and i cant find a guide.
Old Aug 24, 2014 | 11:38 AM
cossynut2's Avatar
cossynut2
10 Year Member
Thumbs up
Hi I have got the Reyland hydraulic conversion on my 2wd Sapphire. The tunnel does not need modifying but as you are probably aware you need to get a mounting welded onto the bell housing . It is not the easiest thing to do but you will be amazed at the difference it makes, well worth the effort.
Cheers Richard.
Old Aug 24, 2014 | 03:34 PM
luke_rs1800
Cheers Richard.
thanks budy. i have a converted bellhousing but it was in a mk2 escort so the mount that have made is a bit big causing it to hit the tunnel so i should beable to trim the bracket and make it fit!
yatta
May 21, 2016 10:31 PM
mark r
Sep 29, 2015 07:27 PM
IainRS1700T
Sep 25, 2015 06:44 AM
talon1
Sep 15, 2015 10:27 AM
Flateric_2002
Sep 15, 2015 08:41 AM
