Help!! 1.7 Puma Died, wont start????????????
Was in the car earler and the car died while going to
freeway . When you put the key and turn it the dash will come on and all electrics work but it wont start. The starter won't work and there are no noises from the relays or fuel pump? i'm suspecting the immobiliser/ecu is at fault.
Also the remote locking is still working fine.
Something like that happened to you before?
I need help
I need help
