spring issue?
Old Aug 23, 2014 | 07:55 PM
essexRSTSouthend's Avatar
essexRSTSouthend
Default spring issue?
Hey everyone. I'm thinking of changing my springs as it seems to me that over the years I've noticed the front height dropping more and more. More so than the back.
Currently using pi springs,fitted for around 4 years. Before this i had Spax but they snapped 2 years in a row. Pi have been fine but I've noticed handling is becoming sloppy and the front wheels tucking into the arches is starting to bother me. All bushes are power flex apart from the rear drums area.
My question is are avo or cobra springs worth buying and if so what ones..
I've had apex but found these as a full kit to be track use only. I forgot to mention I'm still using Spax dampers,, want to change the spring make to see if the car handles better and no more sagging?
Old Aug 23, 2014 | 08:36 PM
studabear's Avatar
studabear
The guy who mapped my car speaks highly of the cobra springs iirc
I'm running some kilen lowering springs at the minute, happy with them so far.
Old Aug 24, 2014 | 11:03 AM
moesin2005's Avatar
moesin2005
could be something more than the springs im having trouble with negative camber on the front and have just fitted new standard springs and shocks and just cant put my finger on what is causing the problem
Old Aug 24, 2014 | 09:45 PM
essexRSTSouthend
I'm planning for the car to have tracking done. Just seems a bit typical it all happens since tyre change
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
IainRS1700T
Sep 25, 2015 06:44 AM
L1AM_RS
Sep 23, 2015 03:27 PM
