G Reg Escort RS Turbo Restoration
Old Aug 16, 2014 | 06:24 PM
onionlover's Avatar
onionlover
Default G Reg Escort RS Turbo Restoration
Hi Everyone. Got my escort in the garage now and started stripping everything off to inspect it for rust. Found quite a bit but wasn't expecting it to be mint. Hoping to start getting the rust removed and treated/replacing panels.
Got a few pictures from around the car of the main rust points.
Old Aug 16, 2014 | 06:30 PM
onionlover's Avatar
onionlover
Having stripped the car it's obvious that it's been used as a track car at some point. Under the carpet was checker plate glued into the driver's foot well. It was sat on koni adjustable dampers, with the shortest hardest springs ever. The spare was a well worn track style tyre as well.
It's been previously maintained with a less than sympathetic attitude. These were the brake pads when i removed them.
As you can see only part of the pad has worn so I assume the wrong diameter disc have been used.
Old Aug 16, 2014 | 06:32 PM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
Got your work 'cut out' (literally !) there mate ! Good luck chap
Old Aug 16, 2014 | 06:33 PM
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
its a heck of a project , I would re-shell it ,
Old Aug 17, 2014 | 05:56 PM
RSmark84's Avatar
RSmark84
Thats a rotter for sure. My D plater had half of the rot. you got a lot of work ahead of yourself.
Old Aug 17, 2014 | 06:09 PM
jonfoc's Avatar
jonfoc
A couple of cheap mint shells out there. I'd resell that.
Old Aug 17, 2014 | 06:38 PM
Rsturbowayne's Avatar
Rsturbowayne
There's a really good mercury grey shell near Colchester !
Old Aug 17, 2014 | 06:57 PM
stevos's Avatar
stevos
Is the last three letters of the reg yoo as my mate had one with bad rot in similar places.
Fair play to you for attempting to repair it.
Old Aug 18, 2014 | 05:24 AM
onionlover's Avatar
onionlover
Unfortunately I live on the north coast of scotland so getting shells up isn't going to be the easiest or cheapest.
As for the repairs I think I'll be a fairly competent welder by the end of it.
Old Aug 18, 2014 | 09:19 AM
0150carmac's Avatar
0150carmac
a heck off a project you got on your hands there but with a good bit off work it can be saved
Old Aug 18, 2014 | 06:13 PM
onionlover's Avatar
onionlover
With a bit of luck it might just be ready in time to be my 3 month old daughter's first car
Old Aug 18, 2014 | 07:42 PM
JOHNDQ's Avatar
JOHNDQ
lol hope we still have petrol then
Vincereese
Jun 1, 2023 09:14 AM
3i Jim
Nov 20, 2015 05:12 AM
Vincereese
Aug 18, 2015 03:57 PM
muz
Aug 16, 2015 12:57 PM
adriansaleem
Aug 1, 2015 09:28 PM
